My TD 6 sat for a year, it was covered. Clutch lever too hard to operate. I had left the clutch disengaged. Will try to
adjust the clutch through the round inspection cover. I know about the bolt and lock to adjust the tension -rockford
over center clutch
What I want to know: Have worked on the clutch assembly when I had the engine out 15 years ago. Is it a hard job to
remove the clutch assembly when assembly in frame? Large cover plate to be removed. Possible set up a come a long
attaching it to the cab roof.
Any information appreciated
over center clutch
