Mr. T. Minnesota
Forum,
Is there a least intrusive method to release a possible stuck oil pressure relief valve? For the past five years of owning this particular crawler the oil pressure has pegged to the right even when running at normal temps. I am using 15-40 weight diesel oil. Just received a pdf of the operators manual and it states the needle should be centered not buried to the right. To this point I have had no issues with operation of the crawler. Any and all thoughts are welcome.
