I looking to see what it takes to rebuild com pump.
I have 45 psi when rpm near 2000. If i push clutch in it goes up to 65psi. Tractor will move on flat ground and if i let off thottle a little it seems to want to grab or engage a little more.
It has new filter, proper level and fluid. The control valve moves nice, clutch regulator spring hieght in spec. Not sure about convertor pressure regulator.
