Mr. T. Minnesota
Forum,
I want to reinstall a 6 volt generator on my R2 Cat. Tried it before and finally figured out how to make the generator charge at a higher rate. It will not have a voltage regulator, just a diode unit as a cut out. Question is does an R2 have negative or positive ground? This particular R2 has a 6 volt electric starter, not pony starter. If negative ground I will simply run a line to the positive post on the battery. Any and all thoughts welcome.
One more thought it has an Eiseman mag which is independent from the charging system.
