Wanted to give a thanks to Jonathan_B for his info posted on
2/9/2021 about the location of the coolant drain on a kubota
v1505 that I have in my bobcat s100.
The valve is located on the front of the engine opposite the
engine door-under the 1.5inch hose that is under the alternator.
On mine, the drain hose is zip tied to the fuel primer hose and
was buried in dirt. Once I found it and dug it out, it was easy to
follow the line straight to the valve.
