Wyatt379x
New User
I have a D6C dozer and the track adjuster will not take grease. Does anyone have the part number for that new grease zerk
unless it is a different fitting than the standard one it should eithe be 1/8 pipe thread or 1/4 straight thread like a 1/4 inch bolt.
If it's the new style with the grease zerk separate it is 1/8 NPT zerk, if it is the old style valve and zerk all one piece you have to buy the valve 2S5925, or you can cut off the zerk, drill and tap the hole to take a zerk, I cannot find a picture of the new style valve, found one of the old style.
AJ
