Fiatallis fl10-C crawler
Right05
New User
Crawler worked perfect had a belly pan fire it was put out Immediately only had to replace one hydrolic line. After we replace the hose the crawler will not turn. No matter witch peddle you push it only stops. Every thing else works perfectly. Any ideas or help would be greatly appreciated
This post was edited by Right05 on 06/27/2022 at 12:56 pm.
Is there three pedals in the floor. I suspect your new hose is someway pulling down the center
STOP pedal . If you did not cross up some lines has to be something making that center pedal
work.
Yes 3 peddles we only Replaces one hose and installed it right back where the damaged hose came from.
Still say something is pulling the middle pedal when you took the floor boards out you have something catching that middle pedal , take the floor boards out and watch and see wht is catching the middle linkage
