Ron Bailey
Hello I have a D3b CAT dozer. I recently replaced the left
steering clutch. But ran into a problem with the arm on the
clutch in not going back in place correct. The distance between
the piston cylinder that pushes the arm out is over extended
and the arm is against the wall. The arm will not push out any
further to activate the clutch and arm will not push towards the
cylinder. I have taken the whole clutch unit in and out about 10
times looking for a problem that I can not find. Had no
problem with this when I took the clutch out! In the picture I
have the stop screw extended out as far as it will go. The
screw has since been removed to try to give the arm room to
move
move
