cat 426 serise 2 backhoe
urbancase
I just pick one up on auction for the farm, has a cab and needs a few cracked windows replaced over time. my real question is it stated backhoe is slow but front loader works fine and drivers well, that said the same pump supply's hyd for the unit from what I can understand. would this be a pop off valve or something like that being the problem? its not home yet so I have not had hands on yet so just asking the question to get pointed in the right direction. also is they any good or bad on these machines ? let me know if you have anything that been a problem. working on getting all the manuals for this also now. thanks in for advance on comments.
First thing is to check the resolvers. A quick test is to operate the backhoe, and then start to raise the loader and see if the backhoe speeds up. If so, the resolver(s) are not letting the ball move freely.
