Mr. T. Minnesota
Forum,
Just returned from northern Minnesota a day before the snow arrives tonight, 5-8 inches.
It was a case of three steps forward and five back!! Installed the cleaned injector pump, preheated the block with a tank heater and charged the battery to full capacity. All was going well until I tried to turn over the engine. Very slow and not as I left it a month ago. Called the my starter tech and he offered advice. Removed the starter and brought it back home to find out it checked out fine. Last bit of info I offered to the starter tech was that the starter came out very easy, too easy. Point being that the starter was not grounding to the bell housing as it should???? Three forward and five back!! When I return next spring I will sand the housing and the nose fitting on the starter a little and may add another form of ground for the starter. Any and all advice is appreciated!
Happy Holidays
Happy Holidays
