I have an odd one that I am hoping I can get some input on.
I have a 1978 IH 3300B Skid loader with a Wiscolnsin VG4D engine.
The issue is it wont crank, no clicks, nothing. It started while I was turning it over, it just stopped while cranking. I had the started rebuilt and replaced the solenoid, but I am not sure if it was the correct solenoid.
I can jump the solenoid and it will start, I havce replaced it with two used ones and a new one but still have the same issue. here is the odd part, the solenoid has the two big posts and two small ones, one small one has the yellow wire that goes to the ignition, the other post is empty. If I take a test light and touch it to the empty one the machine will get stuck with the ignition engaged and wont quit until I pull the battery cable off (does this with the key on or off)
I have also replaced the ignition with no change.
I am completely at a loss and would appreciate any input on this.
Thank you for reading.
