Hydraulic cylinder prices
You want to be sure the rod diameter is equal to the one you have now. A smaller diameter will increase the likely hood of bending the rod and a larger rod diameter reduces the force on the retract (rod) side of the piston.
The cylinder Jim NY is replacing has a 2
inch rod. I had to go to a 4 inch
cylinder to get the 2 inch rod. A 1.75
inch rod in the 3.5 inch bore might be
close enough. A lot of cylinders in that
size have a 1.5 inch rod which is iffy.
Sorry for having to spell out inch the
site strips out the inch symbol.
