713 BH cylinder much needed
Jim In NY
Hi all: I am in need of a good used Crowd cylinder for my Ford BH Model: 713 Series 19-154 (12ft)... the lift cylinder is the same on this model so either one or BOTH will get my baby back to me ! I had purchased two used ones that I thought were "good to go" but it just didn't work out for me as both rods were frozen in the barrels, and as such the barrels and all were NG. The one I had mounted on th BH is completely shot so any parts there are not usable as well ! The BH is mounted on my '62 FORD 2000 industrial tractor(gas). I am always greatfull for any and all help anyone may assist me with, whether it be a part location or someone (anyone) that may lead me to a solution in finding a good used one (or two) ( i can dream can't I). I CaN BE REACHED VIA EMAIL OR phone number if preferable.. Thanks to one and all
Ad a look around and it does not look like there's any available, take a complete assembly for measuring purposes to a decent hydraulic shop and they should be able to replace the barrel and supply a new rod, threaded and the eye welded on and seals etc, over the years I had several new barrels and rods made up for all sorts of machines, it is the done thing rather than buying new from the dealership.
AJ
Aj: thanks for ur input, last time I
checked a new cyl. From the dealer was
$2500 + ship and tax...., and money is
tight like many folks these days! I'm
thinking if I go the refurbish route it
will cost me the same if not more ??
(quoted from post at 09:47:00 09/27/21) Aj: thanks for ur input, last time I
Check Specialty Hydralics in Pleasantville Pa. I've had 5 cylinders rebuilt there this past year. I feel they are very reasonable.
