Company Logo (800) 853-2651 Shop Now
is there alternative for seals on Roosa Master fuel pump
rbp
09-14-2021 13:00:59
Is there any alternative or improvement for the seals that go on Roosa Master fuel injection pump? Thanks.
rbp
09-15-2021 08:37:12
 Re: is there alternative for seals on Roosa Master fuel pump in reply to rbp, 09-14-2021 13:00:59
Thanks for info. I might have a bad lift pump.
rbp
09-15-2021 08:14:37
They seem to give out on me and leak fuel into engine.
Al Baker(pumpman)
09-15-2021 08:25:19
 Re: is there alternative for seals on Roosa Master fuel pump in reply to rbp, 09-15-2021 08:14:37
I have seen the pilot tube leak and the seals get blamed. Most times it is a worn pilot , or folded over lip. I pressure test each repaired pump to 20 psi. If these seals will hold that they will certainly hold while in normal use. Al
Al Baker(pumpman)
09-15-2021 07:28:32
I repair pumps regularly that are 40, sometimes 50 years old that the lip seals are still doing their job, they are here for some other issue. Not sure what more a guy could ask for. Any pump thats got much age on it will need new seals and pilot tube, but that adds 25 bucks to a repair bill. Now it is good for Many, many years. Pretty cheap for the number of years they last. If seals are failing, something is causing this. Al
rustred
09-15-2021 06:35:30
i have not heard of any. what problem are you having with the seals? i remove and replace the pumps all the time and use the same ones, just have to be careful not to fold the lip.
Today's Featured Article - Restoration Story: Fordson Major - by Anthony West. George bought his Fordson Major from a an implement sale about 18 years ago for 200.00 (UK). There is no known history regarding its origins or what service it had done, but the following work was undertaken alone to bring it up to show standard. From the engine number, it was found that this Major was produced late 1946. It was almost complete but had various parts that would definitely need replacing. ... [Read Article]
Latest Ad: Looking for a 1939 or 40 minneapolis moline rtn or rts [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
