Fast cycle switch 580D
Is there a way to unhook the fast cycle switch on a 580D case backhoe. I pushed mine down, and now it's stuck down and now I can't get it up. New ones are not available, so wondering if it's possible to
unhook it some way. Any ideas would be helpful.
AJ Thanks for responding. Fast cycle switch is used to disengage the transmission when you need maximum power for loader. The red button on top of loader control lever controls this. Mine is stuck down and no way can I get it up. How can I bypass this. Herald.
That is known as the clutch cut out, there is one on the floor and one on the loader bucket lever, if it's the one on the floor you can disconnect it, go under and take one of the wires off, you should take the switch off and free it out the dust boot is probably missing off it. if it's the one on the lever you can disconnect it at the solenoid on the shuttle, just part the plug on the pig tail.
AJ
I mis read your reply and thought it was the floor switch that is stuck down, the lever button can be removed by taking the rubber boot off and unscrewing the switch, count the number of turns as you undo it this will be helpful when fitting the new one, fit the new switch and turn it anti clock the number of turns that undone it that way the wires will not be twisted when the switch is home, the switch is no longer available from Case, Google the part # D91440 only and see what it brings up.
AJ
AJ Thanks for the reply. The tractor is out in a very muddy field right now. Putting some tile in, so when it dries up alittle I'll go out and try your suggestions. I'LL you known what happens. Herald
