Mr. T. Minnesota
Forum,
Had a family reunion this weekend and had a chance to install the refurbished injectors on the HD3 Allis. Finally tried to start the engine but did not get it to start. The pump is pulling fuel but is not getting to the injectors. One injector was bubbling but no fluid visible. Will try again in 4-6 weeks. Looking at the exhaust it is heading in the right direction. May have to pull the pump again.
With all this commotion if you have followed this one year story I also had trouble with the manual primer. Thought I had it cured but it would not pull from the tank. Finally took it completely apart and found the same gunk that was in the tank, pump and injectors. Small check valves were glued/stuck in the primer body. Cleaned it and now it pumps as it should. Wish this was in my back yard instead of 170 miles away!! Any and all comments are welcome.
