Oldiron1955
I have to revisit this issue after a long break due to life, but... The owner sent the injection pump for the old Int out for rebuild The serial # is 239DT2D181162 on the block behind oil filter. I replaced the pump with another from a company he found as the other pump was not rebuildable, age wear etc. I installed the pump and thought it was all set, it runs like a top at idle but lack any kind of power to climb a hill or dig just plain lacks power. The exhaust is quite black under load. I tried to move the injection pump but am only able to move it a small amount due to the injection lines. Has anyone else run into this type of problem? I have not removed the injectors yet and am a bit worried as they appear to be rusty where they go into the head and I believe they have cups they sit in and just dont wish to make more work for myself but I think its coming.
