Company Logo (800) 853-2651 Shop Now
D6c master link bolts broken
Milk
07-19-2021 13:55:15
My master link bolts on my track broke out in the field and I dont know how to remove the female half of the link!Bolts are broken down in the block and I am having trouble drilling out in the field! My thought is to take off the female half of the link, take it to my shop sand drill press them out.What is the process to remove the pin holding the master link? Any ideas would be greatly appreciated! Thanks!!
markct
07-24-2021 10:33:27
 Re: D6c master link bolts broken in reply to Milk, 07-19-2021 13:55:15
You aren't going to drive those out with a hammer, the reason the alligator link is there is because it takes about a 150 ton press to remove the pins
AJ.
07-20-2021 15:18:04
Yes clean up any burrs that it may have gotten, those pins don't usually come out but if you are worried heat the very end at the edge and give it a few blows of the hammer to blur it over a smidgen.
AJ
AJ.
07-20-2021 10:11:57
Yes the pin can be got out that way, a suitable drift close to the diameter of the pin weld a handle to it and have a second person to hold it while you get some exercise in on a 14Lb hammer, if you are going to replace the link you can cut two slots on the pin boss of the old link if you don't have a torch use a cutting disc on a grinder, keep close to the pin but don't damage it, it will be a lot easier to get it out then, do both sides, the pins are not meant to be taken out that's why the alligator link, not an easy job any way you do it, did the bolts come loose or did they break while you were trying to undo them.
AJ
Milk
07-20-2021 13:56:10
 Re: D6c master link bolts broken in reply to AJ., 07-20-2021 10:11:57
They were broken off, three of them. The other one was stripped out.
We got the alligator link out by putting alot of heat to it on the outside of the track and wedging cold chisels as we applied heat to it . Now trying to drill out and tap old bolts out, not going too well. Can I reuse the old pin after beating it off the link?It came off but had to use force behind it. Im concerned that the pin wont stay put after reinstalling it back the way it came out! Thanks again!
AJ.
07-19-2021 23:53:54
Split the link, weld something ie a smaller bolt to the broken piece, heat the link where the broken bolt screws into from the outside and gently try to unscrew it, if you are not experienced at doing this type of work get a welder that is.
AJ
PS, I cannot view your picture or video, might be the easiest for you to replace the link if the bolts can't be got out.
This post was edited by AJ. on 07/20/2021 at 02:17 am.
Milk
07-20-2021 03:53:58
 Re: D6c master link bolts broken in reply to AJ., 07-19-2021 23:53:54
Okay,thanks for the reply! I am going to have to get the link off of the track though, its out in the woods now! Can the track pin be driven out with a sledgehammer? Again thanks AJ!very helpful advice
AJ.
07-19-2021 16:33:35
I take it you are talking about the alligator link on the SALT track, the way I removed broken bolts was weld something to them, heat the link (not the bolt) where the bolt is in and get it red hot and unscrew the broken bolt, you need an experienced heavy equipment welder to do this type work.
AJ
Milk
07-19-2021 17:48:05
 Re: D6c master link bolts broken in reply to AJ., 07-19-2021 16:33:35
Yes, the alligator link How do I remove bolts when broken off down inside the block?
Today's Featured Article - A Lifetime of David Brown Tractors - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
Latest Ad: Gemmer hydraguide 954 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
