Not sure if this is the best place to post this question, but I've got a Gehl 4515 skid steer that makes a grinding noise at various points when driving at slower
speeds and lower rpm, seems to be if moving lever into a turn. Machine has two handle control, with left control lever running the drive. I get a
shaking/vibration in that control lever as well when the grinding occurs. Bearings in axles are new and chains have correct tension. Is there some adjustment that
could be out of whack in the hydrostatic pump control linkage?
