Recently i bought a mid 70s MF 33 Loader with a 4-248 perkins engine. it has a dead spot on flywheel, also an air problem in the Fuel system from hell.. I can get it bled so it will turn around 1400 RPM and that takes some time and ether.. and then in a blink of an eye lost 100 percent progress and full of air again.. Ive replaced filters a couple times (along with o rings) replaced feed line from tank, lift pump, checked all injector lines nothing seems to be sucking air.. Could it be a injector sticking open and forcing compression back into the fuel system???? Also does this flywheel have a replaceable Ring gear? thank you in advance. Josh
