I have Cat D4 7U loader. I bought last fall for $1500
The radiator has a big hole at the bottom of it. All bolts have been removed from the radiator and mounting bolts as well.
I have a 44 Hydraulic Control in front of the radiator. I have undone the 4 bolts between the Module and the radiator. I removed the front cover and have cleaned all the gunk from the inside. The filter will be cleaned with gasoline. I have to order a few parts that were found missing when uncovering the cover.
1. I need to know how to remove the Module Control from the front of the radiator?
2. How to remove the radiator so can replace the fan belt
