Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
Draining JD 550 Dozer transmission fluid
Author |
[Modern View] |
macpeppers
01-09-2021 06:58:28
1985 550c dozer. is the drain plug under transmission in the center
Jim.ME
01-09-2021 17:52:14
Re: Draining JD 550 Dozer transmission fluid in reply to macpeppers, 01-09-2021 06:58:28
550 serial numbers 238320 - 261195 are 1976 machines. Your machine's serial number falls in that group, so yours is a 1976 straight 550 with a 6405 blade. That T at the ends tells it was built at the Dubuque Tractor Works.
Check your manual, there should be a suction screen in the opposite side of the case from the drain that you should check/clean while you have it drained. Also check about the steering clutch oil. As I mentioned before, I think it is shared with the transmission and the steering clutch housings will need to be drained and refilled as well. If they are shared, they hold way more oil than the converter.
macpeppers
01-10-2021 08:34:39
Re: Draining JD 550 Dozer transmission fluid in reply to Jim.ME, 01-09-2021 17:52:14
thanks again Jim, good information, i bought the dozer used and he told me it was 1985, oh well. i downloaded an owners manual and it look to have all the info i need, i found the screen you mentioned, apparently you drain the transmission by removing the screen and i found plugs for the steering clutches. this manual is much better for maintenance, the shop manual i guess is more for repair. i still dont know what that plug under the transmission is for. you've been a big help.
Jim.ME
01-09-2021 14:38:06
Interesting in that John Deere doesn't show a 550C on their previous models page or in a parts catalog, It looks like they jumped from the B series to the G series. What is your complete serial number? You may have a 550 C where the C means a 550 with a 6405 (6 way inside mount hydraulic) blade.
On the Powershift transmission (3 forward,3 reverse) I believe the drain plug is in the lower left side, front corner of the Powershift housing. I think the transmission shares oil with the steering clutches so if you are doing an oil change/service those compartments should be drained as well and new oil installed. Again I am not 100% sure on the info I gave you but think it is right. The right operator's manual for the machine would be a big help to you. And be sure to use Hy-Gard or an oil meeting John Deere's J20C spec.
macpeppers
01-09-2021 16:49:23
Re: Draining JD 550 Dozer transmission fluid in reply to Jim.ME, 01-09-2021 14:38:06
thanks Jim, i think you're right, the decal says 550 but the serial # tag says 550-C and it is a 6-way dozer blade. the serial # is 252281T. i've got the 700+ page shop manual and it shows a plug where you said. it doesn't show a plug in the center bottom of the housing but i can't figure what it would be but a drain. my trans oil is milkey so i would like to get as much of the old oil out as possiable. i'm guessing a lot will stay in the torque converter.
macpeppers
01-09-2021 07:04:46
i'm having trouble posting a pic. what i think is the plug has a 1 1/4" round head with no shoulders or recess for a allen wrench. if it is the plug, how do i get it out?
macpeppers
01-09-2021 09:35:19
Re: Draining JD 550 Dozer transmission fluid in reply to macpeppers, 01-09-2021 07:04:46
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
