Company Logo Shop Now
Case 580D schuttle replacing
herald h ia
01-08-2021 14:39:31
How hard is it to remove and replace the shuttle transmission on a 580 D backhoe. Mine is getting weaker and weaker. Changed oil and no difference. Done with tiling till spring so thought we could work on it this winter. Tractor is in very good shape other than that Got a heated shop, so we'll try and work on it. Closest case construction shop is 125 miles away, and agriculture shop don't want to work on it.
herald h ia
01-13-2021 15:13:02
 Re: Case 580D schuttle replacing in reply to herald h ia, 01-08-2021 14:39:31
Thanks for the replies. Try and get started next month. Let you know how We did.
yellowcrawler
01-12-2021 16:21:30
I removed the shuttle shift on my 580D, installed a rebuild kit and put it back in. Rather straight forward to remove and replace. With the manual as a guide, installing the rebuild kit was not bad. The clutches were worn out and the selector shaft was seriously damaged from previous work. That was about 10 years ago and has worked well since.
mjsnodgrass
01-08-2021 22:23:20
i have a 580E. the shuttle id bolted on engine like a normal transmission. pretty straight forward to remove. i used a transmission jack. if were 20 years younger i'd probably not bothered with the jack. shuttle is fairly heavy, but manageable. use your outriggers and something under the bucket to get machine high enough to get jack with shuttle out from under it. few hoses, few electrical connections and a driveline is all there is. good luck. if you're going to all the trouble to rebuild it, replace the torque converter as well.
Today's Featured Article - Restoration Story: 1929 McCormick-Deering 10-20 - by Randal Simmon. On July 4th 1998 my dad and I was sitting on the front porch when he said that he was going to sell his two 10-20's to a junk man. He said that the junk man was going to give him $500 for both of them but he hadn't received the money for them yet. So I went into the house and wrote him a check for $500 and bought them myself and said now they are mine. He had bought them about five years before thinking that he was going to restore them himself. After five years sitting in the barn, he changed h ... [Read Article]
Latest Ad: John Deere 50 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
