Crawlers, Dozers, Loaders & Backhoes Discussion Forum |
LMC Trackmaster
Author |
[Modern View] |
Track Master
01-02-2021 12:07:46
Hello all, I hope I can find some information here. I have a 1999 LMC Trackmaster 85 that has been a great machine for me for many many year. Recently the left track drive started acting up. I was wondering if anyone has any information on what might be the cause. Thank all of you in advance for the help.
John.
AJ.
01-05-2021 03:01:58
Re: LMC Trackmaster in reply to Track Master, 01-02-2021 12:07:46
OK before you pull the motor check the control as I had problems with other makes that had dampers on the control linkage and when they go weak the valve is engaging and disengaging, yours may not have those dampers but its worth a look.
AJ
Track Master
01-08-2021 18:00:15
Re: LMC Trackmaster in reply to AJ., 01-05-2021 03:01:58
Thanks AJ I will look into that as well.
AJ.
01-03-2021 16:06:04
Check out the drive train, like the track and sprocket, what is happening, is the track jerking, is the sprocket slipping, check the sprocket is tight, is the track worn where it meshes with the sprocket, those are a few things on the outside to check.
AJ
Track Master
01-04-2021 08:43:44
Re: LMC Trackmaster in reply to AJ., 01-03-2021 16:06:04
Thank you AJ, the sprocket is good, the teeth engage fully into the track and the track is tight. The movement of the drive is sluggish under load. I got a message under the main forum form another Trackmaster owner that leads me to believe that the drive motor is in need of being rebuilt.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
