Oldiron1955
Working on a 1975 ish International 3500A backhoe with a 239 engine in it and I'm trying to get info on removing the injection pump. I have put the mark on the dampner at about 14* but cant be 100 percent sure as the pointer was badly bent and I got it close to straight. I found the mark in the pump cavity and have it on the line. My question is can I remove it now or do I need to rotate the engine until all the marks on the timing gears line up, I have put paint marks on the gears to be safe. If I do need to rotate the engine do you have any idea how many times will be required to get them all line up. Thanks in advance Mike
