International Dresser TD20 Dozer DTV573 return line seal
Trying to find the return line seals for an International Dresser TD20 Dozer DVT573 diesel engine injectors.
Rough dimensions of the seal are.
.270" tall.
.475 OD
..25 ID (seals to the .250 OD return line)
Thank you so MUCH for any direction on where to get these or optional replacement seals!
(quoted from post at 03:49:04 10/07/20) Komatsu took over Dresser,did you try the Komatsu dealer.
AJ
Did not know that, THANKS!
I did find a seal which "seems" to work for a Massey Tractor.
These are ALL referred to as SLEEVE SEALS
I finally found a part listing for the seal.
IH 685158C1
and also same as (supposedly)
FORD F4TZ-9C387-A - O RING
Hope this helps somebody else!
Thanks!
Good you are going again,about the picture posting on here I think you have to have done a certain amount of posts before you can upload pictures.
AJ
