transmission fluid w7 loader
The manual for my w7 loader calls for type A transmission fluid in the torque converter and transmission and also in the hydraulics. I would like to change it and was wondering if trandraulic fluid would be better. I know in Oliver hydroshift transmissions, they originally called for automatic transmission fluid but later changed the recommendation to transdraulic fluid because bearing and other parts were not holding up the transmission fluid.
The oil specs have changed many times since that machine was new,we use in all Case equipment old and new Case TCH or any generic HyTrans oil of the same spec,there does not seem to be any problems with it.
AJ
