Dune Country
So i got the injector pump in my 580K, thank you AJ and Diesel for the help.
Running great!
Got to digging and lost hydraulics, shut 'er off and lifted the hood, OMG what a mess, I assume the pressure hose from the pump let loose. leak appears to be just behind and below the fan shroud, it dumped the whole hydraulic tank in a matter of seconds on the engine.
I plan to lift the boom, bucket and outriggers remotely and unhook the crankshaft coupler and drive it 200' to the barn, and Give it a hot water bath
AJ or Diesel, if it is the pressure line is it a job, remove hard nose and radiator?
where does the line go to?
Hope it's not the pump ;>]
TIA
AE
Running great!
TIA
AE
