Hey everyone,
I just finished my restoration project, my T-340 drott crawler (picture attached I hope) and all works well except when I'm in the higher gears it will not pull uphill, just stalls and sounds like the engine is straining, but if i'm in the low gear it pushes fine and will spin the tracks (so no clutch issue I would think) My T-340 has the reverser shifter and 4 gears (I think). Any idea why it would be weak in the higher gears. Also motor is tuned and running perfect so no issue there. The right side hand brake works better than the left, I think the right side brake hangs every so often as well but was hoping use would resolve that.
