Case 188 how to pull injectors
Case guy told me try to free up engine before ripping it down before rebuild he thinks it’s only one Cly froze pour marvel’s mystery oil down engine is a parts machine
When you are loosening the injector line nut use two wrenches so you do not twist the injector stem and crack it,there is a special tool to use with a slide hammer available from Case for pulling the injectors,I have got them out without it using a heel bar and patience.
AJ
