WANTED : Webster front hyd pump for parts
marlin54
I am searching to see if anyone has this style of front driven Webster pump for parts . It is on the front of my AC 615 backhoe .
You might have a better chance if you have a look at any tag that maybe on your pump and get all the details off it,Websters make a lot of pumps,there are Webster pumps offered on ebay but again you need details, the Case 580D had that type Webster pump with the two outlets equipment and steering if the GPM were the same you may be able to find one of them easier.
AJ
Thanks for the info. what years do you think that they had those pumps on
them? Someone told me they think the dual pump i have has a 8.5 gpm for backhoe and 15.5 gpm for loader and might or might not have a priority
valve built in it . heres some pics
There is no priority valve in that pump. On the ones that do, it is obvious. The end housing is very different with caps/plugs/etc. As I recall, that type was used on the AC 200 farm tractor.
There is firm in uk that specialise in Hyd pumps , if you are interested let me know
I am in uk and will do it as favour
well someone had it apart and tried to fix it so it needs some parts. it has a small drip coming from between 2 sections and the gear set is a little worm and I think it could use a front plate too.
