Has anyone ever rebuilt a four cyl. Hercules? Got the block bored over .040 and I have all the bearings, new aluminum pistons and rings. and ready to start the rebuild. My problem right at the start is don't know which way to put the rods into the pistons. Top of rod is the kind with the split side and a bolt that clamps up around the wrist pin. My manual says put the bolt on the same side as the split in the aluminum piston, away from the camshaft. Another page says all the factory stamps on the rods and caps go on the cam side. That will put the bolt on the other side of the piston. Anybody know what way is correct? Ron
