580D Case backhoe
Having trouble with a borrowed backhoe, when go to move forward or reverse with the shuttle shift, it hesitates for a bit then a slight jerk and will move. It does not matter what gear the trans. is in. What could be the problem
The shuttle may be low in oil,check it,bucket in the air,safety bar in place,parking brake on,transmission in fourth gear,engine running on low idle,shuttle in forward,pull the shuttle dip stick,wipe it and dip the oil, Case TCH or any generic HyTrans oil will do fine,do not over fill.
AJ
I hate to ask a stupid question, is that the dipstick in floor board?? I checked it but not in all the correct position as mentioned.
No, the dipstick is in the engine compartment,remove the right hand side engine cover sitting in the seat,you will find the shuttle dipstick in the back corner above the starter motor,it's a tee facing you that has to be undone to the left a few turns in order to pull it out.
AJ
