Gehl 2500 skid steer
Can someone explain the wheel drive system on this
loader? It appears there is oil preasure feeding the
drive motors but also a belt driven shaft going into
the drive motor. Thanks, Bob
There is a pump/motor assembly for each side. The pumps are belt driven from the engine by a shaft & pulley between them. Each motor has a chain sprocket that sticks through the side steel to drive the chain to the wheels. The speed/direction of each side is controlled separately by the position of the handle.
