NH L785 Injection pump
Corzolek
New User
Does the injection pump from a MF 165 with perkins a4.203 will fit/work on a NH L785 with the perkins a4.203? Dpa numbers are different, but is the timing and pressure the same.
MF part # dpa 3240f938
NH part # dpa 3343f780
Thank you in advance for any insight.
Physically the pump will fit it is the settings of the pumps that may differ,if for example the high idle and low idle differ on the application it is used for the part numbers would differ,or turbo on one and not the other.
AJ
I did a double check that is the dpa off the pump and what new holland part number references searching that way.
