Re: Cat D3 transmission losing pressure
AJ.
05-25-2020 02:52:53
That's rotten luck after all you put into it,that's a big drop in pressure from start up, does it move any bit at all, the pressure dropping like that would suggest a bad internal leak, it is hard to say what might be the cause a sealing ring or a cracked hub, the first gear hub was known to crack but I don't think that knocks out the other gears, look at the drawing of the oil circuit from where it leaves the pump to pressurize a clutch you might spot a likely spot where it could be leaking, the controls are moving the valves correctly.
AJ
