tinner2004
New User
Sorry for the long post, but I want to be thorough. Thanks in advance for any advice/insights.
My loader was (is) running okay for a
couple minutes then bogs down,blows white smoke and dies. This all started a couple years ago. I read all about it and learned theres a part in the inj. pump that breaks down and clogs the return line, and this pump wont work if it cant get rid of excess fuel. So as a band-aid i took of the return check valve and it ran good for the next 9 months or so. I dont used it a ton, just for cleaning the drive and projecrsaround the yard.
Then last fall the band aid quit working. Will only run a couple minutes then dies.
Since then I've:
-Had the inj. pump rebuilt.
Replaced return lines and blew them out
-Reinstalled check valve
-replaced fuel filters
-and the diesel shop said the injectors were within specs.
Tonight i ran the return from the injectors and pump seperatley to a 2 liter bottle to watch what happened. Ran at full throttle for a couple minutes and the pump let off about 16oz. before it sputtered and died. Nothing came from the injectors.
Ive spent all this time chasing down the return, but that doesnt seem to be the problem. This is my first diesel, and i dont know where to look next. I'm out of ideas at this point. Any advice would be appreciated.
Since then I've:
