Just bought thi 850D. Not bad shape. One major problem with the blade. It does not want to lift when pushing dirt. Everything else is normal. Blade will lift when not wedged against the dirt. When going down it has plenty of power.
I reversed the hoses on both cylinders. Now to raise the blade I move up in lower position. The up works great now and the down has now power. This makes me think control valve issue. There is an anticavitation valve that is on this valve body. Could this be the issue? Could it be leaking and not allowing pressure to build up? I would appreciate any help and ideas for parts availability. Thanks JS
