Company Logo Shop Now
TractorLinks.com
1980 john deere 410
Tcowboy12
03-26-2020 01:42:08
I have a john deere 410 that wont start. Is a flywheel turning tool available for this model? What should i troubleshoot first?
Jim.ME
03-27-2020 05:22:25
 Re: 1980 john deere 410 in reply to Tcowboy12, 03-26-2020 01:42:08
When looking for most parts in the parts catalog you will need the serial number for the tractor, not the engine. That is the number used to identify and date your machine. That tag should be in one of two places (they moved it somewhere along the way). The first place they were located was on the right side of the transmission, towards the rear of the foot rest and above the transmission dipstick. The next location it might be is on right side of the front support, above the front axle.
Jim.ME
03-26-2020 15:01:11
It could be any number of things but really checking and reporting results one thing at a time often yields better results than "shotgunning" for ideas.
You said you rewired the starter button and put a new starter on it. What does "no luck" mean? Nothing energized so nothing happened; or did everything energize, the starter engaged but didn't turn the engine at all? If that is the case you need to try turning it by hand. If nothing energized you need to start by checking to see if it got power to the starter when you pushed the button.
Was it running when it caught fire? Is the oil still in the transmission? Did it burn hydraulic hoses off? How is the hydraulic oil level?
JDEM
03-26-2020 10:42:31
No flywheel turning tool I am aware of. Deere had them for Waterloo engines. 410 has a Dubuque 300 series engine. There is a timing pin and cover. You can take off the cover and use a big screwdriver to turn the engine over (if my memory is correct).
Jim.ME
03-26-2020 04:42:15
It helps to have all the info since people on a forum can't see it, even if something seems obvious to you.
Giving us the following info will help. Straight 410 or a 410 letter series? Tractor with loader, with backhoe? Gas or diesel? Was it running and quit or was it running, you worked on it, and now it won't start? If it happened after you worked on it exactly what did you do/work on? Or did you just get it and it has never started for you? Does it spin over freely when the starter is used? You are looking for a flywheel turning tool. Does that mean it won't turn over?
The service manual usually tells if there is a flywheel turning tool and which one is needed.
Tcowboy12
03-26-2020 11:03:35
 Re: 1980 john deere 410 in reply to Jim.ME, 03-26-2020 04:42:15
Straight 410 loader backhoe diesel engine. I bought it non running after it caught fire. Engine serial number 4219DT03 5344467
Tcowboy12
03-26-2020 11:11:00
 Re: 1980 john deere 410 in reply to Tcowboy12, 03-26-2020 11:03:35
The fire was just around the right wheel all it burned is the throttle cable and emergency brake. I rewired the starter button and put a new starter on it with no luck. I just got the wheel broke loose. Could the clutch or wet clutch be froze up?
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
