I have a 1968 580ck backhoe with a #33 hoe. Im trying to identify which one is the the pressure line and the return line on the Hoes valve pack. I took parts off this hoe years ago to fix another 580ck and I had removed some of the hyd hoses ect . Now I cant remember which hoses went where . I have identified the pressure hose that feeds the backhoe valve pack that is coming off the valve that is for the loader because I cranked the engine over and it shoots out of a fitting that is angled off the rear of the valve body { see picture }. so that would be what feeds the backhoe . I have 2 big hoses that come from the valve pack on the backhoe. 1 on each end . so sitting on the tractor , which side of the valve pack does the pressure line from loader valve go to ? right side or left ? and then I believe that both lines going back have 1 way valves in them right ? pressure line has one and also the return has one ? thanks
