1964 IH TD9 Dozier seals
Wingnut1
New User
I am looking for a couple of seals . I took the clutch packs out to get them rebuilt and the seals that are between the release bearing housing and the body of the dozer need to be replaced. Any ideas of where to find them? I've checked several tractor dealers and no luck .
I would take the old seal to a bearing shop and its very likely that they can match it up for you,NAPA is another source that may be able to help.
AJ
I don't know what kind of seal it is, but you will often find a number on a metal component, and these are easily searchable on the web. It probably would have been a standard seal and still available from many sources. Also, if you know the type of seal and the dimensions of the components where it mounts or seals, you can search by that. Should be easy to find.
Brown International Services Inc.
Mailing Address:?
Box 557, Armstrong, BC V0E 1B0
Physical Address:?
4274 Hwy 97A North, Armstrong BC
Phone: (250) 546-6518
Fax: (250) 546-3100
E-mail:[email protected]
https://brownihc.com
