(quoted from post at 04:56:49 02/14/20) Go to the link below there is a video on how to.
AJ
Track adjustment
I think the 301.8 and some others of that series have a plate just behind the idler on the side of the frame you have to remove to get to the grease fitting and valve.
I should have been more specific, the tracks move in and out hydraulically with a cyl. can't find the lever to do it.
Thank you all for responding, the video was helpful. This one has aswitch on rh side you move and then you use the blade lever to move tracks
