I just picked a 410 b and was having some trouble with the gear shift lever. i believe it was because I was missing the small plate on the floor that kind of guides it. So I pulled the larger floor pan off to try and measure the plate that was missing so I could make something to replace it.
When I pulled the floor pan up the gear shift lever came out of the transmission. I believe the snap ring that belongs there is missing. I put the lever back into the transmission and now the tractor won't shift and is stuck in neutral. I'm unsure how to try and fix it and any help would be appreciated. Thanks in advance. [/list]
