Sparkplugs for Ford 4500 TBL
chuckinnc
My old 4500 has a 201ci 3 cly gas engine. I finally got around to taking the old plugs out, they say Autolite 405
I think this is original. Anyway they are hard to find, so does anyone know of a better replacement?
I'm using Autolite 216 in my 4500. I also used them in a 3000 engine. You should be able to get them to Tractor supply.
That crosses to a Champion N8 which is a pretty cold plug, with todays gas I'd switch to a N9Y which crosses to a Autolite 63.
The extended tip on these plugs may help the tractor run better.
Hi Destroked. I have not talked to you for a while . I finished up my 4400 ford backhoe..thanks to you for the steering assy . this time I need a intake/exhaust manifold for a 580 case gas motor. do you have one? or know some who does? thanks marlin in Toledo
