This message is a reply to an archived post by r8f1k on July 25, 2018 at 19:49:27.
The original subject was "Re: Gehl 4500 Skid Steer Stalling OutHard Starting".
Timing may be off a bit. See if turning the distributor a fuzz helps. Condenser may be a problem too. If they aren?t exactly right it can run, but not like it should. Distributor is the same as the early ford tractors? NAA up to the 600 series I believe.
