Oliver HG/OC3 3 Point?
Nailcreek
New User
I?m looking for a 3pt to attach onto an Oliver HG/OC3 for food plot and trail maintenance work. I understand that Oliver offered one as an option, but they appear pretty rare. I've read that Terratrac had one that can be used but haven't seen one used.
So, what options are available? Has anyone drawn up any plans or figured out any alternatives?
Thanks,
Kerry
I've built a few from scratch for tractor I have. Not all that hard to make a 3 point if you have the 2 lift arms and a hyd cylinder and can do some welding. But you also have to have a hyd pump of some sort on the machine and control valve
For hydraulics on my old HG, I put a double pulley on the alternator on it and ran a small belt driven pump from an old combine.
Built a front blade and used 2 cylinders to raise it up.
Used old hydraulic valve off a combine also.
That has been 30 years ago and I sold it after a few years.
Wish I had kept it.
Richard
I've used Chevy type power steering pumps in the past for hyds and they worked just fine
