Hi all,
I couldn't seem to get registered over on the ACMOC site, so thought I would give this one a try. I'm new to the Cat world, came home with a little 22 last week. It runs great, steers great, and pulls pretty well for the most part. Had it out with my pull type subsoiler yesterday and when I'd hit a really tough spot the clutch would want to slip. Need to investigate pedal adjustment a little more, but I think it is okay. Took inspection plate off and everything looks clean and dry. Do any of you guys know, is there any adjustment on the clutch itself? I see there is a nut on each spring on the pressure plate, are these a predetermined setting or can a guy gain anything by tightening them a flat or two? Thanks!
