Farmer Rock
Hi guys,so one of the main reasons i bought the old mf203,is to bring water out to the cows.right now we only got a couple cows out in pasture,but by spring we'll be getting a herd in there,which brings up a problem,"water",so i have been using the cih 585 tractor that i use for general things,mower,phd,pullin wagon,but the problem was i kept having to switch back and forth from the 275 tote on wagon,to whatever implement I'm using,so i figured if i used the backhoe it would solve that problem,so do you guys think a decent set of clamp on forks thats rated for around #3000 would be able to handle 275 gal almost every day,i am currently changing all fluids and filter,so i am confident the loader will lift it,but I'm not sure how to keep all that weight where it needs to be.
Thankyou,Rock
Thankyou,Rock
