JD hydraulic filter U17122
Good morning I am trying to source a filter for for JD 450straight dozer . It is the replaceable filter inside the hyd resevoir.
My local dealer says its discontinued. Does anybody know of a cross match or a aftermarket filter for this?
Thank You
Mike
(quoted from post at 08:14:39 10/15/19) Good morning I am trying to source a filter for for JD 450straight dozer . It is the replaceable filter inside the hyd resevoir.
Thank You
Mike
Your dealer did a darned poor job of helping you!
From jdparts.com...
"SUB U41343 filter, 24H1314 (flat washer) AND 08H4497 (3/8" X 9.5" bolt)"
Latest "sub" is to AT45422, still available from DEERE.
Thanks Bob , the dealer called me back about a hr ago and gave me that info also and they had one in stock.
I now have it in hand. I hope it fixes my problem.
Thanks
Mike
Bob i got the filter ok but now i cant get the tank top of hydraulic tank took all the bolts out and it will only lift up about 3/4" seems like something is hitting the underside of the tank rim
Any thoughts
Mike
