RAY ZAMISKA
Have looked high and low for the oil sending unit on my JD 350-B diesel. According to the parts manual it should be located in
the front area of the motor ahead of the temperature sending unit. Just can"t locate it. Also original unit does it function with
less than 12 volts. Are there any other instruments that operate at less than 12 V. water temp sender??? Have installed a single
wire alternator and read some things from other posts it may be less than 12 V.. Any help is appreciated. Regards RJZ
